Macro voor fysieke resetknop maken
Re: Macro voor fysieke resetknop maken
brunolundh schreef: 29 jul 2024 23:20 I think alot of what I try to communicate is lost in translation because I’m Swedish 😅
It's the intended purpose of derailing a topic as soon as we can. The fact that it's still about CNC is a miracle on itself. Don't worry, you're doing fine.
Can you please elaborate on what it is you exactly want?
-Do you want to kill the machine at once
-do you want a subtle pause?
(both features are standard in Eding by default).
Please tell us what situation you want with as detailed as possible.
serum schreef: 30 jul 2024 11:42 -Do you want to kill the machine at once
There you also have a translation issue :mrgreen:
So above question is meant as kill switch aka
Do you want an emergency brake, emergency stop (E-stop), emergency off (EMO), or emergency power off (EPO), is a safety mechanism used to shut off machinery in an emergency, when it cannot be shut down in the usual manner.
In case you're wondering. Kjelt is the safety-guru around here. He takes life and safety circuits way too serious. :mrgreen:
If you have a safety-related question, he'll probably kill your motivation from doing anything you had in mind.
At least I am not trying to kill your machine :mrgreen:
It only takes a little imagination and willingness to understand a question. Refusing to understand any question takes a different type of person.
serum schreef: 30 jul 2024 13:42 It only takes a little imagination and willingness to understand a question. Refusing to understand any question takes a different type of person.
True!.. but where is the fun, if you disregard any pun, intended or not?
Anyway, the question was "Can i make a Physical Button to "reset" the machine, and is there a way to write a macro to handle that button?
I think it is a good idea to tell us what version of EdingCNC you are using, and what you want to achieve with said button:
;Remove comments if you want additional reset actions
;when reset button was pressed in UI
;sub user_reset
;    msg "Ready for operation"
;endsub
as you can see, there is a "reset" subroutine in the MacroFile, it is "commented out" in mine, as i don't have any other functions in there
But you can put any function in there if so desired..
Arie Kabaalstra schreef: 30 jul 2024 13:54
;sub user_reset
;endsub
Sorry, maar als ik die code lees, zie ik alleen een routine die de boodschap Ready for operation weergeeft via standaard IO.
Ik zie geen 'reset' functionaliteit aangeroepen worden.
Zoals een 'short to ground' bijvoorbeeld zou triggeren
zoals ik al schreef.. "je kunt er zelf alle code in gooien die je wilt"
al is het een G00G53Z0 (als je Machine Z0 boven ligt.. )
heb je een IO kaart eraan hangen.. dan kun je zelfs een belletje ergens anders af laten gaan als er op de Reset gedrukt wordt..
Met een io kaart kan je zelfs je koffiepot aanzetten.
Ja.. dan moet ik em in de Start Subroutine zetten.. dat heb je goed gezien!..
andrefc101 schreef: 31 jul 2024 16:34 Met een io kaart kan je zelfs je koffiepot aanzetten.
Je kan nog veel meer leuke dingen met een IO kaart aan en en uit zetten.
En met G Code kan je ook hele andere dingen laten bewegen :lol: :mrgreen:
Jazeker, gaaf hè!
andrefc101 schreef: 31 jul 2024 17:36 Jazeker, gaaf hè!
<droom> <droom> <droom>
mlrs
Bericht door mlrs »
Zoals de TS later heeft aangegeven gaat het niet om de "reset" button. Volgens mij gaat het om de "machine on" button die gebruikt wordt i.c.m. een safety relais zoals wordt beschreven op pagina 61-63 van de manual (Document Release 4.03)
Zelf ben ik hier eigenlijk ook naar opzoek.
