PC problemen
aletheamartinez
PC problemen
Bericht door aletheamartinez »
Shark NV360 vs NV352: Which One Is Better?
META: This Shark NV360 vs NV352 comparison will show you the similarities and differences between those two vacuums to help you with your purchase decision.
The Shark NV360 and the NV352 seem to be nearly identical models if we put them side by side. This is pretty confusing for most customers as they wonder if there is any difference between them. Learn more about these upright vacuums and whether you should upgrade to the NV360 from the NV352.
Shark NV360 vs NV352: A Comparison
  • Similarities
Both the NV352 and the NV360 belong to Shark's Navigator, an upright vacuum series with many premium features at relatively low prices. At first glance, it'll be hard for you to tell these two vacuums apart. Though the NV360 has some minor tweaks in design, they both bear a traditional look of a Shark upright. Even the dimensions and weights are identical at 14.5x11.4x45.5 inches and 12.50 pounds.
This design is known for its tendency to topple easily, however. When you pull the hose too hard, the heavy top can make the whole machine fall over as the hose seems to not be able to stretch out easily.
They feature many unique high-end technologies from Shark. For instance, the Lift-Away design allows users to detach the canister from the main body and carry it to vacuum narrow areas such as stairs. Another important similarity is the filtration system.
The NV352 and the NV360 are both equipped with the Anti-Allergen Complete Seal Technology. This means no matter which model you end up with, you still benefit from top-notch filtering performance inside a completely sealed system. This system doesn't only captures 99.9% of dust particles and allergens but also prevents them from escaping and going back to the environment.
Both these upright vacuums also come with swivel steering to allow for higher maneuverability. Thanks to this dynamic steering, you can get around your furniture and obstacles easier, especially when the vacuum needs to lie flat to clean the areas underneath your couch. They have a long 25-foot power cord, which should be enough for most people unless you plan to vacuum a massive area that doesn't have any power outlets.
Their performances on different surfaces are almost identical as well. Both work exceptionally well on hardwood floors. Just a couple of passes, and they can already get rid of most dirt and dust, down to the tiny grooves. Low-pile carpets pose no issue to these upright either.
However, things start to change when it comes to thick carpeting. The wheels of the NV352 and NV360 don't seem to roll quite well on thick carpets, while the rollers also have trouble rotating properly.
Important Site: Shark vacuum NV360
  • Differences
While the Shark Navigator Lift-Away NV360 is supposed to be a small upgrade from the NV352 with no significant change in the principle design, there are still some minor differences between them.
For example, with the NV352, Shark gives users a 5-inch crevice tool for stair and corner cleaning, while the NV360 features a slightly bigger 5.5-inch tool. On top of that, the dust cup of the NV360 is also larger at 1.2 quarts compared to the 1.1-quart capacity of the NV352. This doesn't make much of a difference in most real-life scenarios, though.
Final Verdict
The Shark navigator lift away deluxe NV360 upright vacuum resembles the NV352 in many ways. It's basically just a minor upgrade with minimal changes. If you're already happy with your NV352 and thinking about a new vacuum with more advanced features, think about another model instead.
Laatst gewijzigd door aletheamartinez op 24 jan 2024 09:21, 2 keer totaal gewijzigd.
Re: PC problemen
Dat is zo iets als: Mijn auto doet het niet meer, wat zou er aan de hand zijn.
Waarschijnlijk is er niemand die hier een antwoordt op kan geven zonder dat er meer informatie komt ;-)
Portje
Re: PC problemen
Bericht door Portje »
Formatteren, windows installeren en daarna de programma's die je wil.
Ik ben er dan bijna van overtuigd dat de computer dan weer goed werkt.
Re: PC problemen
Portje schreef: 27 feb 2023 17:08windows
Aha, daar begint de eerste veronderstelling al, de vraagsteller gaf deze info niet.
Maarrrr, laten we eerst even wachten op een reactie om te zien of deze persoon nog terug keert.
Nu geef ik iedereen in eerste instantie het voordeel vd twijfel maar onlangs ook nog dit bij de hand gehad :
lettertypes in Filou nc12
https://cnczone.nl/viewtopic.php?t=21681
Re: PC problemen
keesfrees schreef: 27 feb 2023 17:36
Fusion, Norton, Avast. ;-) Of gebruik je dat tegenwoordig ook al bij Linux?
Re: PC problemen
Nee gelukkig niet !
van : https://en.wikipedia.org/wiki/Fusion_360
Operating system Windows, macOS, Android, iOS[2]
geen linux idd
Re: PC problemen
nah, met Wine kan je Fusion ook onder linux draaien hoor :mrgreen:
En in een virtualbox met win10 doet ie het onder linux ook uitstekend :lol:
WillyH
Re: PC problemen
Bericht door WillyH »
Portje schreef: 27 feb 2023 17:08 Formatteren, windows installeren en daarna de programma's die je wil.
Een beetje met een kanon op een mug schieten. Indien er geen backup voorhanden is, ben je een dagje kwijt aan installeren en herinstalleren, en duurt het weken eer alles weer naar je eigen hand staat.
Een garagist zal ook niet snel een hele motor uitbouwen omdat deze wat sputtert. Probeer stap voor stap te werken en bepaalde zaken uit te sluiten. Soms is het gewoon zaak om even enkele dagen te wachten en is door een update een bug verholpen.
Re: PC problemen
Windows an sich is met een Kanon op een Mug schieten.
Waarom kost alleen het Operating System al meer dan een 1Gb aan diskruimte?!?
En dan kan je eigenlijk nog weinig zinnigs met die computer.
Dan moet er nog office en de rest op.... :mrgreen:
Oeps... die was te goedkoop :lol:
Re: PC problemen
hainjedaf schreef: 01 mar 2023 13:06 Oeps... die was te goedkoop :lol:
Het hoeft ook niet perse allemaal de hoofdprijs te kosten. :mrgreen:
Re: PC problemen
Re: PC problemen
Libreoffice / Openoffice gebruik ik al jaren.
En als je hem instelt op 'save as docx/xlsx' heb je weinig problemen in de windows wereld.
Het zijn uitsluitend die lastige formules uit het 'analysis toolpack' waar spreadsheets zich op stukbijten.
Die zijn propriëtair en al zo lang excel bestaat, de reden van het succes van het programma.
Die formules waren destijds de reden voor Bill Gates op excel op te kopen en in M$office in te lijven.
Wat mis ik WP5.1/6.0 met de onderwatermodus.
