Linuxcnc start niet op in nieuw OS
Na het instaleren van debian werkt mijn configuratie niet meer, ik krijg deze melding:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.6
LINUXCNC - 2.7.14
Machine configuration directory is '/home/sven/linuxcnc/configs/Alu-XYZA'
Machine configuration file is 'Alu-XYZA.ini'
INIFILE=/home/sven/linuxcnc/configs/Alu-XYZA/Alu-XYZA.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./Alu-XYZA.hal
hm2: loading Mesa HostMot2 driver version 0.15
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0:     IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 010 (P3-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0:     IO Pin 011 (P3-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0:     IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0:     IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0:     IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
hm2/hm2_5i25.0:     IO Pin 015 (P3-12): Encoder #0, pin B (Input)
hm2/hm2_5i25.0:     IO Pin 016 (P3-13): Encoder #0, pin A (Input)
hm2/hm2_5i25.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
Found file(LIB): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
xhc-hb04.tcl: Using existing outpin signame: spindle-cmd-rps-abs
Starting TASK program: milltask
DELAY=
APP: xhc-hb04-accels found: </usr/bin/xhc-hb04-accels>
APP: monitor-xhc-hb04 found: </usr/bin/monitor-xhc-hb04>
Starting DISPLAY program: axis
[color=#FFBF40]ERROR Can't open the device /dev/spindelregeling (errno 22)
vfd: ERROR: couldn't open serial device[/color]
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1675
Killing task milltask, PID=1713
task: 86 cycles, min=0.000006, max=0.021240, avg=0.008012, 0 latency excursions (> 10x expected cycle time of 0.010000s)
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Vervolg hieronder.....
Met name de regel " ERROR Can't open the device /dev/spindelregeling (errno 22)
vfd: ERROR: couldn't open serial device" is denk ik een dingetje.
Ontbreken er dan drivers voor de seriële poort?
Re: Linuxcnc start niet op in nieuw OS
Vervolg foutmelding:
Debug file information:
pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM
./Alu-XYZA.hal:4: Warning: File contains DOS-style line endings.
Note: Using POSIX realtime
xhc-hb04.tcl: using std_start_pause_button
Can not find -sec APPLICATIONS -var DELAY -num 1
open: No such file or directory
custom_postgui.hal:6: waitpid failed hy_vfd vfd
custom_postgui.hal:6: hy_vfd exited without becoming ready
1675
  PID TTY      STAT   TIME COMMAND
1713
Stopping realtime threads
Unloading hal components
libusb: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusb: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x000055e0521d0aa0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7f10b12eebfb]
/lib/x86_64-linux-gnu/libc.so.6(+0x76fc6)[0x7f10b12f4fc6]
/lib/x86_64-linux-gnu/libc.so.6(+0x7780e)[0x7f10b12f580e]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(+0xb935)[0x7f10b183f935]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_unref_device+0x77)[0x7f10b1838f47]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_exit+0x23c)[0x7f10b183a5dc]
xhc-hb04(+0x2539)[0x55e050628539]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f10b129e2e1]
xhc-hb04(+0x257a)[0x55e05062857a]
======= Memory map: ========
55e050626000-55e05062b000 r-xp 00000000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082a000-55e05082b000 r--p 00004000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082b000-55e05082c000 rw-p 00005000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082c000-55e05082e000 rw-p 00000000 00:00 0
55e0521a9000-55e0521f9000 rw-p 00000000 00:00 0                          [heap]
7f10ac000000-7f10ac021000 rw-p 00000000 00:00 0
7f10ac021000-7f10b0000000 ---p 00000000 00:00 0
7f10b0658000-7f10b0659000 ---p 00000000 00:00 0
7f10b0659000-7f10b0e59000 rw-p 00000000 00:00 0
7f10b0e59000-7f10b0e71000 r-xp 00000000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b0e71000-7f10b1070000 ---p 00018000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1070000-7f10b1071000 r--p 00017000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1071000-7f10b1072000 rw-p 00018000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1072000-7f10b1076000 rw-p 00000000 00:00 0
7f10b1076000-7f10b107d000 r-xp 00000000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b107d000-7f10b127c000 ---p 00007000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127c000-7f10b127d000 r--p 00006000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127d000-7f10b127e000 rw-p 00007000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127e000-7f10b1413000 r-xp 00000000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1413000-7f10b1613000 ---p 00195000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1613000-7f10b1617000 r--p 00195000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1617000-7f10b1619000 rw-p 00199000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1619000-7f10b161d000 rw-p 00000000 00:00 0
7f10b161d000-7f10b1633000 r-xp 00000000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1633000-7f10b1832000 ---p 00016000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1832000-7f10b1833000 r--p 00015000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1833000-7f10b1834000 rw-p 00016000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1834000-7f10b184b000 r-xp 00000000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b184b000-7f10b1a4b000 ---p 00017000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4b000-7f10b1a4c000 r--p 00017000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4c000-7f10b1a4d000 rw-p 00018000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4d000-7f10b1bbf000 r-xp 00000000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1bbf000-7f10b1dbf000 ---p 00172000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dbf000-7f10b1dc9000 r--p 00172000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dc9000-7f10b1dcb000 rw-p 0017c000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dcb000-7f10b1dcf000 rw-p 00000000 00:00 0
7f10b1dcf000-7f10b1ed2000 r-xp 00000000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b1ed2000-7f10b20d1000 ---p 00103000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d1000-7f10b20d2000 r--p 00102000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d2000-7f10b20d3000 rw-p 00103000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d3000-7f10b20d6000 r-xp 00000000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b20d6000-7f10b22d5000 ---p 00003000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d5000-7f10b22d6000 r--p 00002000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d6000-7f10b22d7000 rw-p 00003000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d7000-7f10b22df000 r-xp 00000000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b22df000-7f10b24de000 ---p 00008000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24de000-7f10b24df000 r--p 00007000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24df000-7f10b24e0000 rw-p 00008000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24e0000-7f10b2503000 r-xp 00000000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2675000-7f10b26c0000 rw-s 00000000 00:05 1376273                    /SYSV48414c32 (deleted)
7f10b26c0000-7f10b26c5000 rw-p 00000000 00:00 0
7f10b26c5000-7f10b26e4000 r-xp 00000000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e4000-7f10b26e5000 r--p 0001e000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e5000-7f10b26e6000 rw-p 0001f000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e6000-7f10b26e8000 rw-p 00000000 00:00 0
7f10b26fe000-7f10b26ff000 rw-p 00000000 00:00 0
7f10b26ff000-7f10b2700000 rw-s 00000000 00:05 1310736                    /SYSV48484c34 (deleted)
7f10b2700000-7f10b2703000 rw-p 00000000 00:00 0
7f10b2703000-7f10b2704000 r--p 00023000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2704000-7f10b2705000 rw-p 00024000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2705000-7f10b2706000 rw-p 00000000 00:00 0
7ffcfcd97000-7ffcfcdb8000 rw-p 00000000 00:00 0                          [stack]
7ffcfcde8000-7ffcfcdea000 r--p 00000000 00:00 0                          [vvar]
7ffcfcdea000-7ffcfcdec000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
RTAPI_PCI: Unmapped 65536 bytes at 0x7faad85b5000
Kernel message information:
[    0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000c9d5dfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c9d5e000-0x00000000c9d64fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000c9d65000-0x00000000ca5a7fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ca5a8000-0x00000000ca7e4fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ca7e5000-0x00000000da38efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da38f000-0x00000000da426fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000da427000-0x00000000da462fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da463000-0x00000000da523fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000da524000-0x00000000daffefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dafff000-0x00000000daffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. H81-D3/H81-D3, BIOS FC 08/10/2015
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask 7F00000000 write-back
[    0.000000]   1 base 0100000000 mask 7FE0000000 write-back
[    0.000000]   2 base 00E0000000 mask 7FE0000000 uncachable
[    0.000000]   3 base 00DC000000 mask 7FFC000000 uncachable
[    0.000000]   4 base 00DB800000 mask 7FFF800000 uncachable
[    0.000000]   5 base 011F800000 mask 7FFF800000 uncachable
[    0.000000]   6 base 011F600000 mask 7FFFE00000 uncachable
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd6e0-0x000fd6ef] mapped at [ffffa0af800fd6e0]
[    0.000000] Base memory trampoline at [ffffa0af80097000] 97000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x106dc0000, 0x106dc0fff] PGTABLE
[    0.000000] BRK [0x106dc1000, 0x106dc1fff] PGTABLE
[    0.000000] BRK [0x106dc2000, 0x106dc2fff] PGTABLE
[    0.000000] BRK [0x106dc3000, 0x106dc3fff] PGTABLE
[    0.000000] BRK [0x106dc4000, 0x106dc4fff] PGTABLE
[    0.000000] BRK [0x106dc5000, 0x106dc5fff] PGTABLE
[    0.000000] BRK [0x106dc6000, 0x106dc6fff] PGTABLE
[    0.000000] BRK [0x106dc7000, 0x106dc7fff] PGTABLE
[    0.000000] BRK [0x106dc8000, 0x106dc8fff] PGTABLE
[    0.000000] BRK [0x106dc9000, 0x106dc9fff] PGTABLE
[    0.000000] BRK [0x106dca000, 0x106dcafff] PGTABLE
[    0.000000] BRK [0x106dcb000, 0x106dcbfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x3521b000-0x36904fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DA4F1078 00006C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DA4FD988 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000DA4F1178 00C80C (v02 ALASKA A M I    00000088 INTL 20091112)
[    0.000000] ACPI: FACS 0x00000000DA522080 000040
[    0.000000] ACPI: APIC 0x00000000DA4FDA98 000062 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DA4FDB00 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DA4FDB48 000539 (v01 PmRef  Cpu0Ist  00003000 INTL 20120711)
[    0.000000] ACPI: SSDT 0x00000000DA4FE088 000AD8 (v01 PmRef  CpuPm    00003000 INTL 20120711)
[    0.000000] ACPI: MCFG 0x00000000DA4FEB60 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x00000000DA4FEBA0 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT 0x00000000DA4FEBD8 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[    0.000000] ACPI: SSDT 0x00000000DA4FEF48 0034E1 (v01 SaSsdt SaSsdt   00003000 INTL 20091112)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x11f5fb000-0x11f5fffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000011f5fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000c9d5dfff]
[    0.000000]   node   0: [mem 0x00000000c9d65000-0x00000000ca5a7fff]
[    0.000000]   node   0: [mem 0x00000000ca7e5000-0x00000000da38efff]
[    0.000000]   node   0: [mem 0x00000000da427000-0x00000000da462fff]
[    0.000000]   node   0: [mem 0x00000000dafff000-0x00000000daffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000011f5fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
[    0.000000] On node 0 totalpages: 1021732
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 13895 pages used for memmap
[    0.000000]   DMA32 zone: 889224 pages, LIFO batch:31
[    0.000000]   Normal zone: 2008 pages used for memmap
[    0.000000]   Normal zone: 128512 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000dba00000-0x00000000df9fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xc9d5e000-0xc9d64fff]
[    0.000000] PM: Registered nosave memory: [mem 0xca5a8000-0xca7e4fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda38f000-0xda426fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda463000-0xda523fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda524000-0xdaffefff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffffa0b09f200000 s437952 r8192 d28992 u1048576
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u1048576 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1005744
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3914704K/4086928K available (6391K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 172224K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:33024 nr_irqs:440 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3092.793 MHz processor
[    0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6185.58 BogoMIPS (lpj=12371172)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000011] ACPI: Core revision 20160831
[    0.006765] ACPI: 5 ACPI AML tables successfully acquired and loaded
[    0.006784] Security Framework initialized
[    0.006785] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.006789] AppArmor: AppArmor disabled by boot time parameter
[    0.007180] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[    0.009027] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.009499] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.009502] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.009733] mce: CPU supports 7 MCE banks
[    0.009741] CPU0: Thermal monitoring enabled (TM1)
[    0.009751] process: using mwait in idle threads
[    0.009753] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.009753] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.009755] Spectre V2 : Mitigation: Full generic retpoline
[    0.009755] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.009755] Speculative Store Bypass: Vulnerable
[    0.010080] Freeing SMP alternatives memory: 24K
[    0.011186] ftrace: allocating 25230 entries in 99 pages
[    0.028378] smpboot: Max logical packages: 1
[    0.028687] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.068375] TSC deadline timer enabled
[    0.068377] smpboot: CPU0: Intel(R) Pentium(R) CPU G3240 @ 3.10GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.068380] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.068397] ... version:                3
[    0.068398] ... bit width:              48
[    0.068398] ... generic registers:      8
[    0.068399] ... value mask:             0000ffffffffffff
[    0.068399] ... max period:             00007fffffffffff
[    0.068400] ... fixed-purpose events:   3
[    0.068400] ... event mask:             00000007000000ff
[    0.124674] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.176863] x86: Booting SMP configuration:
[    0.176864] .... node  #0, CPUs:      #1
[    0.179189] x86: Booted up 1 node, 2 CPUs
[    0.179191] smpboot: Total of 2 processors activated (12371.17 BogoMIPS)
[    0.180554] devtmpfs: initialized
[    0.180617] x86/mm: Memory block size: 128MB
[    0.182067] PM: Registering ACPI NVS region [mem 0xc9d5e000-0xc9d64fff] (28672 bytes)
[    0.182068] PM: Registering ACPI NVS region [mem 0xda463000-0xda523fff] (790528 bytes)
[    0.182113] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.182121] futex hash table entries: 512 (order: 4, 65536 bytes)
[    0.182156] pinctrl core: initialized pinctrl subsystem
[    0.182258] NET: Registered protocol family 16
[    0.187169] cpuidle: using governor ladder
[    0.188905] cpuidle: using governor menu
[    0.188922] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.188923] ACPI: bus type PCI registered
[    0.188924] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.188971] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.188973] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.188977] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.189056] PCI: Using configuration type 1 for base access
[    0.189106] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.189695] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.189785] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.189786] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.189914] ACPI: Added _OSI(Module Device)
[    0.189915] ACPI: Added _OSI(Processor Device)
[    0.189915] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.189916] ACPI: Added _OSI(Processor Aggregator Device)
[    0.190072] ACPI: Executed 1 blocks of module-level executable AML code
[    0.193875] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.194510] ACPI: Dynamic OEM Table Load:
[    0.194514] ACPI: SSDT 0xFFFFA0B099A9A000 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20120711)
[    0.194804] ACPI: Dynamic OEM Table Load:
[    0.194807] ACPI: SSDT 0xFFFFA0B099A92800 0005AA (v01 PmRef  ApIst    00003000 INTL 20120711)
[    0.195099] ACPI: Dynamic OEM Table Load:
[    0.195102] ACPI: SSDT 0xFFFFA0B099A79400 000119 (v01 PmRef  ApCst    00003000 INTL 20120711)
[    0.195773] ACPI: Interpreter enabled
[    0.195795] ACPI: (supports S0 S3 S4 S5)
[    0.195796] ACPI: Using IOAPIC for interrupt routing
[    0.195817] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.202763] ACPI: Power Resource [FN00] (off)
[    0.202825] ACPI: Power Resource [FN01] (off)
[    0.202886] ACPI: Power Resource [FN02] (off)
[    0.202945] ACPI: Power Resource [FN03] (off)
[    0.203002] ACPI: Power Resource [FN04] (off)
[    0.203649] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.203653] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.203826] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.203929] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.203930] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.204228] PCI host bridge to bus 0000:00
[    0.204229] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.204231] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.204232] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.204233] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.204234] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.204235] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.204236] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.204237] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.204238] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.204239] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
[    0.204240] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.204247] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.204322] pci 0000:00:02.0: [8086:0402] type 00 class 0x030000
[    0.204331] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.204337] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.204341] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.204411] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[    0.204418] pci 0000:00:03.0: reg 0x10: [mem 0xf7e14000-0xf7e17fff 64bit]
[    0.204508] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.204522] pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
[    0.204576] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.204609] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.204639] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.204655] pci 0000:00:16.0: reg 0x10: [mem 0xf7e1e000-0xf7e1e00f 64bit]
[    0.204711] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.204778] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.204792] pci 0000:00:1a.0: reg 0x10: [mem 0xf7e1c000-0xf7e1c3ff]
[    0.204868] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.204917] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.204951] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.204965] pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
[    0.205026] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.205062] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.205092] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.205149] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.205213] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.205245] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[    0.205302] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.205362] pci 0000:00:1c.2: System wakeup disabled by ACPI
[    0.205393] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.205450] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.205509] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.205545] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.205560] pci 0000:00:1d.0: reg 0x10: [mem 0xf7e1b000-0xf7e1b3ff]
[    0.205635] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.205678] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.205710] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[    0.205856] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.205868] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
[    0.205874] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
[    0.205880] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
[    0.205886] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
[    0.205892] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.205898] pci 0000:00:1f.2: reg 0x24: [mem 0xf7e1a000-0xf7e1a7ff]
[    0.205929] pci 0000:00:1f.2: PME# supported from D3hot
[    0.205986] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.205999] pci 0000:00:1f.3: reg 0x10: [mem 0xf7e19000-0xf7e190ff 64bit]
[    0.206016] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.206130] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.206197] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.206216] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.206242] pci 0000:02:00.0: reg 0x18: [mem 0xf7d00000-0xf7d00fff 64bit]
[    0.206259] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.206347] pci 0000:02:00.0: supports D1 D2
[    0.206348] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.206390] pci 0000:02:00.0: System wakeup disabled by ACPI
[    0.219249] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.219252] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.219255] pci 0000:00:1c.2:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.219259] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.219336] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[    0.219455] pci 0000:03:00.0: supports D1 D2
[    0.219457] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.219478] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.219506] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.219510] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.219567] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[    0.219590] pci 0000:04:00.0: reg 0x10: [mem 0xf7c00000-0xf7c0ffff]
[    0.219793] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
[    0.219806] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.219815] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[    0.220527] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.220564] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220600] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.220636] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.220671] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220710] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220748] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.220783] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.221032] ACPI: Enabled 4 GPEs in block 00 to 3F
[    0.221130] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.221132] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.221136] vgaarb: loaded
[    0.221136] vgaarb: bridge control possible 0000:00:02.0
[    0.221198] PCI: Using ACPI for IRQ routing
[    0.222452] PCI: pci_cache_line_size set to 64 bytes
[    0.222494] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.222496] e820: reserve RAM buffer [mem 0xc9d5e000-0xcbffffff]
[    0.222497] e820: reserve RAM buffer [mem 0xca5a8000-0xcbffffff]
[    0.222497] e820: reserve RAM buffer [mem 0xda38f000-0xdbffffff]
[    0.222498] e820: reserve RAM buffer [mem 0xda463000-0xdbffffff]
[    0.222499] e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
[    0.222500] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
[    0.222618] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.222623] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.224638] clocksource: Switched to clocksource hpet
[    0.232435] VFS: Disk quotas dquot_6.6.0
[    0.232454] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.232534] pnp: PnP ACPI init
[    0.232667] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.232671] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.232812] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.232813] system 00:01: [io  0xffff] has been reserved
[    0.232815] system 00:01: [io  0xffff] has been reserved
[    0.232816] system 00:01: [io  0xffff] has been reserved
[    0.232817] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.232818] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.232820] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.232821] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.232822] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.232823] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.232825] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.232847] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.232888] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.232890] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.232991] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[    0.232992] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[    0.232993] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[    0.232995] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.233029] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.233212] pnp 00:06: [dma 0 disabled]
[    0.233249] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.233469] pnp 00:07: [dma 0 disabled]
[    0.233560] pnp 00:07: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.233602] system 00:08: [io  0x04d0-0x04d1] has been reserved
[    0.233604] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.233931] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.233933] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.233934] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.233935] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.233937] system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.233938] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.233939] system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.233940] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.233942] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[    0.233943] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.233945] system 00:09: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.233946] system 00:09: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.233948] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.234111] pnp: PnP ACPI: found 10 devices
[    0.240128] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.240162] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.240171] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.240173] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.240177] pci 0000:00:1c.2:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.240179] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.240184] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.240191] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.240204] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.240208] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.240214] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.240216] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.240217] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.240218] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.240219] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.240220] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.240221] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.240223] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[    0.240224] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[    0.240225] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
[    0.240226] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.240227] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[    0.240228] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.240229] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.240230] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.240231] pci_bus 0000:04: resource 4 [mem 0xf7c00000-0xf7cfffff]
[    0.240308] NET: Registered protocol family 2
[    0.240436] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.240599] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
[    0.240981] TCP: Hash tables configured (established 32768 bind 32768)
[    0.241016] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[    0.241084] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[    0.241180] NET: Registered protocol family 1
[    0.241191] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.288748] PCI: CLS 64 bytes, default 64
[    0.288795] Unpacking initramfs...
[    0.584563] Freeing initrd memory: 23464K
[    0.584566] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.584568] software IO TLB [mem 0xd638f000-0xda38f000] (64MB) mapped at [ffffa0b05638f000-ffffa0b05a38efff]
[    0.584863] audit: initializing netlink subsys (disabled)
[    0.584879] audit: type=2000 audit(1546955512.584:1): initialized
[    0.585227] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    0.586550] zbud: loaded
[    0.587266] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.587292] io scheduler noop registered
[    0.587293] io scheduler deadline registered
[    0.587319] io scheduler cfq registered (default)
[    0.587728] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.587732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.587747] intel_idle: MWAIT substates: 0x2120
[    0.587748] intel_idle: v0.4.1 model 0x3C
[    0.587802] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.587899] GHES: HEST is not enabled!
[    0.587949] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.608369] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.608860] Linux agpgart interface v0.103
[    0.608946] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.608946] AMD IOMMUv2 functionality not available on this system
[    0.609098] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    0.609098] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    0.609267] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.609365] mousedev: PS/2 mouse device common for all mice
[    0.609400] rtc_cmos 00:02: RTC can wake from S4
[    0.609512] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    0.609574] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.609583] intel_pstate: Intel P-state driver initializing
[    0.611227] NET: Registered protocol family 10
[    0.611855] mip6: Mobile IPv6
[    0.611861] NET: Registered protocol family 17
[    0.611868] mpls_gso: MPLS GSO support
[    0.612258] microcode: sig=0x306c3, pf=0x2, revision=0x19
[    0.612367] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    0.612791] registered taskstats version 1
[    0.612841] zswap: loaded using pool lzo/zbud
[    0.612957] ima: No TPM chip found, activating TPM-bypass!
[    0.612961] ima: Allocated hash algorithm: sha256
[    0.613904] rtc_cmos 00:02: setting system clock to 2019-01-08 13:51:52 UTC (1546955512)
[    0.614082] PM: Hibernation image not present or could not be loaded.
[    0.617033] Freeing unused kernel memory: 1680K
[    0.617035] Write protecting the kernel read-only data: 12288k
[    0.618754] Freeing unused kernel memory: 1784K
[    0.625605] Freeing unused kernel memory: 1184K
[    0.629468] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    0.638034] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.666547] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.666681] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.666700] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.727731] thermal LNXTHERM:00: registered as thermal_zone0
[    0.727734] ACPI: Thermal Zone [TZ00] (28 C)
[    0.728228] thermal LNXTHERM:01: registered as thermal_zone1
[    0.728230] ACPI: Thermal Zone [TZ01] (30 C)
[    0.734816] ACPI: bus type USB registered
[    0.734843] usbcore: registered new interface driver usbfs
[    0.734856] usbcore: registered new interface driver hub
[    0.735227] usbcore: registered new device driver usb
[    0.735769] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.735981] ehci-pci: EHCI PCI platform driver
[    0.736178] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.736188] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.736201] ehci-pci 0000:00:1a.0: debug port 2
[    0.737821] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    0.737829] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.740102] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.740165] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e1c000
[    0.741099] SCSI subsystem initialized
[    0.749606] r8169 0000:02:00.0 eth0: RTL8168g/8111g at 0xffffb51dc0a7d000, 40:8d:5c:81:32:43, XID 0c000800 IRQ 24
[    0.749609] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    0.752087] libata version 3.00 loaded.
[    0.752693] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.752919] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.752921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.752923] usb usb1: Product: EHCI Host Controller
[    0.752924] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    0.752926] usb usb1: SerialNumber: 0000:00:1a.0
[    0.763213] hub 1-0:1.0: USB hub found
[    0.763225] hub 1-0:1.0: 2 ports detected
[    0.763533] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.763538] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.764617] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[    0.764622] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.766170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.766172] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.766174] usb usb2: Product: xHCI Host Controller
[    0.766175] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[    0.766177] usb usb2: SerialNumber: 0000:00:14.0
[    0.768280] hub 2-0:1.0: USB hub found
[    0.768297] hub 2-0:1.0: 10 ports detected
[    0.772910] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.772914] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.772955] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[    0.772957] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.772958] usb usb3: Product: xHCI Host Controller
[    0.772960] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[    0.772961] usb usb3: SerialNumber: 0000:00:14.0
[    0.773168] hub 3-0:1.0: USB hub found
[    0.773176] hub 3-0:1.0: 2 ports detected
[    0.773405] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[    0.773535] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    0.773589] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    0.774479] ahci 0000:00:1f.2: version 3.0
[    0.774655] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x1 impl SATA mode
[    0.774658] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems
[    0.779170] scsi host0: ahci
[    0.779286] scsi host1: ahci
[    0.779383] scsi host2: ahci
[    0.779481] scsi host3: ahci
[    0.779531] ata1: SATA max UDMA/133 abar m2048@0xf7e1a000 port 0xf7e1a100 irq 26
[    0.779533] ata2: DUMMY
[    0.779533] ata3: DUMMY
[    0.779534] ata4: DUMMY
[    0.779761] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.779766] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    0.779776] ehci-pci 0000:00:1d.0: debug port 2
[    0.783680] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.783718] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e1b000
[    0.796701] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.797160] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    0.797162] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.797163] usb usb4: Product: EHCI Host Controller
[    0.797164] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    0.797165] usb usb4: SerialNumber: 0000:00:1d.0
[    0.797396] hub 4-0:1.0: USB hub found
[    0.797403] hub 4-0:1.0: 2 ports detected
[    1.088744] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.100274] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.100696] usb 2-4: new full-speed USB device number 2 using xhci_hcd
[    1.100858] ata1.00: ATA-9: C300-MTFDBAK128MAG, 0308, max UDMA/100
[    1.100862] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.101634] ata1.00: configured for UDMA/100
[    1.102054] scsi 0:0:0:0: Direct-Access     ATA      C300-MTFDBAK128M 0308 PQ: 0 ANSI: 5
[    1.124724] usb 4-1: new high-speed USB device number 2 using ehci-pci
[    1.136347] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    1.136432] sd 0:0:0:0: [sda] Write Protect is off
[    1.136435] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.136455] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.137062]  sda: sda1 sda2 < sda5 sda6 >
[    1.137535] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.192379] PM: Starting manual resume from disk
[    1.192382] PM: Hibernation image partition 8:5 present
[    1.192383] PM: Looking for hibernation image.
[    1.192544] PM: Image not found (code -22)
[    1.192545] PM: Hibernation image not present or could not be loaded.
[    1.237111] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[    1.237113] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.237401] hub 1-1:1.0: USB hub found
[    1.237485] hub 1-1:1.0: 4 ports detected
[    1.241506] usb 2-4: New USB device found, idVendor=1a86, idProduct=7523
[    1.241508] usb 2-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.241509] usb 2-4: Product: USB2.0-Serial
[    1.273091] usb 4-1: New USB device found, idVendor=8087, idProduct=8000
[    1.273094] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.273242] hub 4-1:1.0: USB hub found
[    1.273339] hub 4-1:1.0: 6 ports detected
[    1.297450] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[    1.298305] random: fast init done
[    1.360694] usb 2-5: new low-speed USB device number 3 using xhci_hcd
[    1.384133] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.388704] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.388806] systemd[1]: Detected architecture x86-64.
[    1.388964] systemd[1]: Set hostname to <cnc-debian>.
[    1.440097] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    1.440110] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    1.440582] systemd[1]: Listening on udev Control Socket.
[    1.440724] systemd[1]: Listening on Journal Audit Socket.
[    1.440761] systemd[1]: Listening on Syslog Socket.
[    1.440910] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.440940] systemd[1]: Listening on udev Kernel Socket.
[    1.465272] lp: driver loaded but no devices found
[    1.466729] ppdev: user-space parallel port driver
[    1.467417] parport_pc 00:07: reported by Plug and Play ACPI
[    1.467485] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[    1.471549] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[    1.505521] usb 2-5: New USB device found, idVendor=046d, idProduct=c408
[    1.505523] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.505524] usb 2-5: Product: USB Trackball
[    1.505525] usb 2-5: Manufacturer: Logitech
[    1.569004] lp0: using parport0 (interrupt-driven).
[    1.600682] tsc: Refined TSC clocksource calibration: 3092.838 MHz
[    1.600687] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c94d9afcf4, max_idle_ns: 440795231738 ns
[    1.628685] usb 2-6: new full-speed USB device number 4 using xhci_hcd
[    1.669450] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.669454] ACPI: Power Button [PWRB]
[    1.670564] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    1.670566] ACPI: Power Button [PWRF]
[    1.701435] systemd-journald[201]: Received request to flush runtime journal from PID 1
[    1.769609] usb 2-6: New USB device found, idVendor=10ce, idProduct=eb70
[    1.769612] usb 2-6: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[    1.769613] usb 2-6: Manufacturer: KTURT.LTD
[    1.860206] hidraw: raw HID events driver (C) Jiri Kosina
[    1.877436] usbcore: registered new interface driver usbhid
[    1.877438] usbhid: USB HID core driver
[    1.913036] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.926275] [drm] Initialized
[    1.972222] [drm] PipeC fused off
[    1.972232] [drm] Memory usable by graphics device = 2048M
[    1.972234] [drm] Replacing VGA console driver
[    1.976290] Console: switching to colour dummy device 80x25
[    1.983827] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.983828] [drm] Driver supports precise vblank timestamp query.
[    2.001984] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.038511] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.043798] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    2.048573] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.048579] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    2.049258] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.050225] snd_hda_codec_realtek hdaudioC1D2: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    2.050227] snd_hda_codec_realtek hdaudioC1D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.050228] snd_hda_codec_realtek hdaudioC1D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    2.050229] snd_hda_codec_realtek hdaudioC1D2:    mono: mono_out=0x0
[    2.050230] snd_hda_codec_realtek hdaudioC1D2:    dig-out=0x11/0x0
[    2.050231] snd_hda_codec_realtek hdaudioC1D2:    inputs:
[    2.050233] snd_hda_codec_realtek hdaudioC1D2:      Rear Mic=0x18
[    2.050234] snd_hda_codec_realtek hdaudioC1D2:      Front Mic=0x19
[    2.050235] snd_hda_codec_realtek hdaudioC1D2:      Line=0x1a
[    2.050236] snd_hda_codec_realtek hdaudioC1D2:      CD=0x1c
[    2.053802] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    2.062595] fbcon: inteldrmfb (fb0) is primary device
[    2.070847] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/input5
[    2.086566] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[    2.095617] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[    2.096777] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    2.096777] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    2.100242] usbcore: registered new interface driver usbserial
[    2.100565] usbcore: registered new interface driver usbserial_generic
[    2.100969] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[    2.101083] usbserial: USB Serial support registered for generic
[    2.103925] usbcore: registered new interface driver ch341
[    2.104328] usbserial: USB Serial support registered for ch341-uart
[    2.104430] ch341 2-4:1.0: ch341-uart converter detected
[    2.104518] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[    2.107404] usb 2-4: ch341-uart converter now attached to ttyUSB0
[    2.124064] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input10
[    2.127786] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input11
[    2.131838] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input12
[    2.140744] Console: switching to colour frame buffer device 210x65
[    2.159125] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.178852] input: Logitech USB Trackball as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:046D:C408.0001/input/input13
[    2.178941] hid-generic 0003:046D:C408.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:00:14.0-5/input0
[    2.179392] hid-generic 0003:10CE:EB70.0002: hiddev0,hidraw1: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:14.0-6/input0
[    2.180056] Adding 4085756k swap on /dev/sda5.  Priority:-1 extents:1 across:4085756k SSFS
[    2.219728] intel_rapl: Found RAPL domain package
[    2.219729] intel_rapl: Found RAPL domain core
[    2.219730] intel_rapl: Found RAPL domain uncore
[    2.219730] intel_rapl: Found RAPL domain dram
[    2.236106] iTCO_vendor_support: vendor-support=0
[    2.242191] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.242477] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[    2.628721] clocksource: Switched to clocksource tsc
[    2.646836] r8169 0000:02:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[    2.719040] r8169 0000:02:00.0 eth0: link down
[    2.719045] r8169 0000:02:00.0 eth0: link down
[    2.719119] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.166113] r8169 0000:02:00.0 eth0: link up
[    5.166130] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.138465] random: crng init done
[   13.138467] random: 7 urandom warning(s) missed due to ratelimiting
(bericht werd te groot...)
Ik heb destijds in jouw /etc/udev/rules.d directory een rule(bestandje) geplaatst die de RS485 adapter altijd aanmaakt als /dev/spindelregeling met de juiste permissies.
Die rule moet je even opzoeken en kopieren naar je nieuwe installatie op dezelfde plek. Dan overnieuw opstarten of 'sudo udevadm control --reload-rules' intikken.
Dawassum, doetutnu!
Dank voor je snelle reactie!
Er staan nog 3 andere rules in die map, moeten die ook mee?
In debian stonden er geen in die map toen ik begon.
welke zijn die anderen?
Ga ik nakijken als ik weer in de werkplaats ben maar eentje was iets met RTAI, dat lijkt me niet voor debian?
DaBit schreef: 08 jan 2019 17:43 welke zijn die anderen?
70-persistent-cd.rules
70-persistent-net.rules
99-rtai.rules
README
javanree
Bericht door javanree »
RTAI is niet van toepassing als je een Mesa kaart draait, dan heb je immers geen RTAI maar preempt-rt kernel.
persistent-cd en persistent-net zijn system dingen, moet je zeker niet zelf gaan copieeren / editen.
Prima, ik blijf er vanaf, dank!
