Ik was aan het stoeien met artcam, en merkte op dat de mach3 postprocessor die te vinden is op het web geen tool change ondersteund, waardoor je per tool een g-code bestand moet maken..
Ik heb dus wat kleine modificatie aangebracht in de postprocessor...
Wie weet loopt iemand hier ook tegen aan en heeft hij er baat bij..
Gr Robo
; G - Code configuration file - with Arc Support
; History
; Who When What
; TM 13/05/99 Written
; BEM 20/05/99 Removed line numbers
; BEM 21/03/00 Added DESCRIPTION and FILE_EXTENSION fields
; BEM 19/06/01 Added support for circular arc output
; move to home pos at end instead of 0,0,ZH
; bem 07/09/01 Added G17 to define plane for circular arcs
; Robo20/07/09 Cleanup, Start, tool change, feedrate metric fix, name change
DESCRIPTION = "RoboCNC Mach3 Arcs Toolchange (mm) (*.tap)"
FILE_EXTENSION = "tap"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Arc Centre Cordinates
FORMAT = [I|@|I|1.3]
FORMAT = [J|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "G00 G17 G21 G40 G49 G80 G90"
START = "T[T] M06 ([TOOLDESC])"
START = "G00 [ZH]"
START = "G00 [XH] [YH] [S] M03"
; Program moves
RAPID_RATE_MOVE = "G00 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "G01 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[X] [Y] [Z]"
FIRST_CW_ARC_MOVE = "G02 [X] [Y] [I] [J] [F]"
CW_ARC_MOVE = "G02 [X] [Y] [I] [J]"
FIRST_CCW_ARC_MOVE = "G03 [X] [Y] [I] [J] [F]"
CCW_ARC_MOVE = "G03 [X] [Y] [I] [J]"
; Robo CNC Tool change
TOOLCHANGE = "G00 [ZH]"
TOOLCHANGE = "M05"
TOOLCHANGE = "T[T] M06 ([TOOLDESC])"
TOOLCHANGE = "[F] [S] M03"
; End of file
END = "G00 [ZH]"
END = "G00 [XH] [YH]"
END = "M30"
